var measurement = 'swap'
var groupBy = ['host']
var whereFilter = lambda: ("os" == 'linux')
var convert_GiB = 0.0000000009313225746154785
var data = stream
|from()
.database(db)
.retentionPolicy(rp)
.measurement(measurement)
.groupBy(groupBy)
.where(whereFilter)
|eval(lambda: float("free") * convert_GiB, lambda: float("total") * convert_GiB, lambda: ceil("used_percent"))
.as('free', 'total', 'usage')
|window()
.period(3m)
.every(2m)
|percentile('usage', 90.0)
.as('stat')
Error it returns:
lvl=error msg="error evaluating expression" service=kapacitor task_master=main task=SWAP_USAGE_LNX node=alert5 err="Cannot call function \"float\" argument \"free\" is missing, values in scope are [\"used_percent\", \"total\", \"usage\", \"usage\"]"
