Hi team, I’m using the telegraf tail plugin+GROK to ingest my custom application logs to Grafana. I can see the log data in the Table visualization, but I want to create an alert email that sends the log level + log message whenever log_level is “ERR”. I’ve set up the notifications channel, but I’m not sure how to create the alerting rule. Any help would be much appreciated.
Hi @curiousghost,
Welcome to the community
. Are you using InfluxDB alerting feature or just Grafana? If Granfana specific then I would recommend dropping a support request on their community. We can help you out with the InfluxDB notification method if that works for you.
We will leave this post up as other community members might drop by and leave you an answer to your query if it is grafana specific.
Thanks Jay. I’m using Grafana, I should’ve probably mentioned this before. Thanks for leaving this post up. Any help is much appreciated.
