Hope this is right forum. I’m using telegraf to poll various nodes via SNMP and then populate InfluxDB
I’ve just noticed that when the node is completely offline or the nodes SNMP service is shut down that telelgraf appears to keep populating Infkux with the last value? Is this normal?
I shutdown a node completely and then ran “telegraf --test --config /etc/telegraf/telegraf.d/node1.conf” and it just timed out…but when I check the InfluxDB it is continuing to get values - my expectation is it would get a null or 0 value
No this isn’t expected, Telegraf will stop reporting for the device if it can’t connect. I think it is unlikely that this is what is happening though, perhaps it’s just a query issue?
