Hi, so I’m having trouble getting some Ruby on Rails logs into InfluxDB using Telegraf. At one point I had something working for the first portion of log entry… and when I tried to add to it, it broke… and I’ve never since been able to get it back to even working for the piece that did work before.
Here’s an example line from the log:
I, [2017-08-14T13:47:07.245469 #2180] INFO -- : Completed 500 Internal Server Error in 43ms (Views: 0.3ms | ActiveRecord: 8.6ms)
Here’s the config I thought worked at first to just capture the Loglevel/severity, Timestamp, and PID…
[[inputs.logparser]]
files = ["/opt/applications/core/current/log/staging.log"]
[inputs.logparser.grok]
patterns = ["%{CUSTOM_CORE_LOG}"]
measurement = "app_core_log"
custom_patterns = '''
CUSTOM_CORE_LOG %{LOGLEVEL:sev:tag}, \[%{TIMESTAMP_ISO8601:timestamp:ts-"2017-08-14T13:47:07.201998"} \#%{POSINT:pid:int}\]
So in my mind, that should match I, [2017-08-14T13:47:07.245469 #2180]
, resulting in sev=“I”, ts=2017-08-14T13:47:07.245469, and pid=2180.
I’m at the point where I can’t even just match the stinkin’ Loglevel… so even a patter of simply %{LOGLEVEL:sev:tag}
doesn’t work for me right now. Even if I don’t make sev a tag.
I need to parse through the whole line, but if I could just get going with at least the first three components, I can hopefully get the rest working… Any help would be greatly appreciated! I’m sure it’s something stupid…
Thanks!
