Hi Everyone,
I’m currently testing Telegraf to populate an InfluxDB Monitoring database. One of my requirement is to monitor GPUs on Windows clients. The problem is that the nvidia-smi Telegraf plugin does work for me.
The plugin wants to collect three encoder stats (namely: encoder_stats_session_count, encoder_stats_average_fps and encoder_stats_average_latency) which are unknown.
When I use the troubleshooting command (from the github plugin page, adapted for powershell)
.\nvidia-smi.exe --format="noheader,nounits,csv" --query-gpu="fan.speed,memory.total,memory.used,memory.free,pstate,temperature.gpu,name,uuid,compute_mode,utilization.gpu,utilization.memory,index,power.draw,pcie.link.gen.current,pcie.link.width.current,encoder.stats.sessionCount,encoder.stats.averageFps,encoder.stats.averageLatency,clocks.current.graphics,clocks.current.sm,clocks.current.memory,clocks.current.video"
I get:
Field “encoder.stats.sessionCount” is not a valid field to query.
And similar results for the two other fileds as I remove them from the command query.
Client specs:
OS: Windows 7
Telegraf: 1.12.3
nvidia-smi: 376.33
GPU: Quadro 4000
Does anyone has encountered the same problem? Could have it working? Has any ideas?
Thank you very much for your help!
