Telegraf parsing/processing JSON data (dynamic field name)
Hello :slight_smile:
I got some issues storing the following data into InfluxDB.
All I need is basically 2 values.
Which isn’t an issue to get but to transform the values into the structure I want.
I tried working with tags, processor->rename, starlark etc. but nothing was successful.
I am requesting multiple sensor data using “inputs.http” plugin.
components[0]->status->value
components[0]->config->name
  "components": [
      "key": "bthomesensor:201",
      "status": {
        "id": 201,
        "value": 34,
        "last_updated_ts": 1777738048
      "config": {
        "id": 201,
        "addr": "...",
        "name": "humidity_kitchen",
        "obj_id": 46,
        "idx": 0,
        "meta": {
          "ui": {
            "icon": null
  "cfg_rev": 50,
  "offset": 0,
  "total": 2
[[inputs.http]]
  name_override = "sensors"
  urls = [
    'http://<kitchen>/rpc/Shelly.GetComponents?keys=["bthomesensor:201"]',
    'http://<other>/rpc/Shelly.GetComponents?keys=["bthomesensor:201"]',
    'http://<outside>/rpc/Shelly.GetComponents?keys=["bthomesensor:201"]'
  data_format = "json"
  tagexclude = ["url"]
The structure I want to archive:
_measurement  -> sensors
_field        -> humidity
 tag          -> room          -> humidity_kitchen
Additionally the value of the tag room should be processed, trimming it’s prefix “humidity_
_measurement | _field   | _value | room
sensors      | humidity | 34     | kitchen
sensors      | humidity | 38     | other
sensors      | humidity | 44     | outside
Additionally I need to get the data of a few other sensor, too.
They follow the same structure but with a different config name.
$ http://<kitchen>/rpc/Shelly.GetComponents?keys=["bthomesensor:202"]
  "components": [
      "key": "bthomesensor:202",
      "status": {
        "id": 202,
        "value": 18,
        "last_updated_ts": 1777745372
      "config": {
        "id": 202,
        "addr": "...",
        "name": "temperature_kitchen",
        "obj_id": 69,
        "idx": 0,
        "meta": {
          "ui": {
            "icon": null
  "cfg_rev": 50,
  "offset": 0,
  "total": 1
Parsed data to store in InfluxDB
sensors      | temperature | 18     | kitchen
sensors      | temperature | 22     | other
sensors      | temperature | 16     | outside
I guess I need to use multiple “inputs.http” configs, to process different data.
The goal is to store humidity, temperature, window and door (opened 1, closed 0).
**Appreciate any help…**
This is driving my crazy for multiple days now.
Or if possible parsing the data even more dynamic using the value of:
temperature_kitchen
temperature_other
humidity_outside
window_other
Parsed maybe via. regex (divider _ ):
FIELD-NAME _ ROOM
sensors      | humidity    | 16     | outside
sensors      | window      | 1      | other
I believe you’re on the right track with trying Starlark. I’d recommend using the json_v2 input plugin instead of json for your data format. By specifying included_keys to the fields you care about, you should be able to extract what you need, then use Starlark to split on the underscore in the humidity_kitchen value to make sure that the single value can get written to two separate columns, with something like:
def apply(metric):
    name = metric.fields.get("components_config_name")
    parts = name.split("_", 1)
    field = parts[0]
    room = parts[1]
    metric.tags["field"] = field
    metric.tags["room"] = room
The rest of it should be pretty easy from there.
You’ll definitely need to do different instances of the input plugin (and processing) for different data models, though.
Thank you very much for pointing me into the right direction.
I literally didn’t know where to start.
Reading docs and examples, inlcuding yours, to starlark, enabling debug logging and trying, trying, trying… finally solved it.
[[inputs.http]]
  urls = [
    'http://<kitchen>/rpc/Shelly.GetComponents?keys=["bthomesensor:202"]',
    'http://<sleeping>/rpc/Shelly.GetComponents?keys=["bthomesensor:201"]',
    'http://<sleeping>/rpc/Shelly.GetComponents?keys=["bthomesensor:202"]'
  json_string_fields = ["components_0_status_value", "components_0_config_name"]
  fieldinclude = ["components_0_status_value", "components_0_config_name"]
  tagexclude = ["url", "host"]
[[processors.starlark]]
  namepass = ["sensors"]
  source = '''
load("logging.star", "log")
def apply(metric):
  log.debug("{}".format(metric))
  name = metric.fields.get("components_0_config_name")
  status = metric.fields.get("components_0_status_value")
  type = parts[0]
  room = parts[1]
  result = Metric(metric.name)
  result.fields[type] = float(status)
  result.tags["room"] = room
  metric = []
  metric.append(result)
  return metric
> sensors,room=kitchen humidity=59
> sensors,room=kitchen temperature=18.2
> sensors,room=sleeping humidity=51
“json_string_fields” is very important to set, as the “config_name” is a string ans “status_value” can be a boolean value.
Shelly BLU devices (windows/doors) return their state as boolean (true/false) which converts to 1/0 using “float(status)”.
If only Telegraf would support digest auth in their http plugin. :disappointed_face:
One problem solved, one ahead.
Hey!
Sorry for the too late response but your solution is way to complex so I’m posting this to document a more simple solution for everyone finding this thread in the future. :slight_smile:
When dealing with more complex JSON data I really recommend the XPath parser as it is often easier to read and can do more that the JSON or JSONv2 parsers. As for example in your case where
[[inputs.http]]
  urls = [
  data_format = "xpath_json"
  xpath_native_types = true
  [[inputs.http.xpath]]
    metric_name = "'sensors'"
    metric_selection = "/components/*"
    field_selection = "."
    field_name = "substring-before(config/name, '_')"
    field_value = "status/value"
    [inputs.file.http.tags]
      room = "substring-after(config/name, '_')"
will directly output the desired format.
> sensors,host=Hugin,room=kitchen humidity=34 1780473541000000000
Thank you for this solution and different approach.
Meanwhile I expanded the code of the starlark processor with different
(if/else) conditions and additional logging to indentify wrongly named devices to drop
their metric in order to not “destroy” the database scheme and report the issue to me.
Unfortunately this can’t be solved with xpath.
It’s always a good things to show multiple ways of dealing with stuff. Thanks! :+1:
