Hi! I am very, very new on Influx matters, I am able to successfully load data from signal key onto influxDB 2. But when trying to load string values, no error is show, but no values are loaded.
Test output is:
pi@openplotter:~/.openplotter/telegraf $ telegraf --config /home/pi/.openplotter/telegraf/self.environment.time.conf --once
2023-07-24T16:52:22Z I! Loading config: /home/pi/.openplotter/telegraf/self.environment.time.conf
2023-07-24T16:52:22Z I! Starting Telegraf 1.27.2
2023-07-24T16:52:22Z I! Available plugins: 237 inputs, 9 aggregators, 28 processors, 23 parsers, 59 outputs, 4 secret-stores
2023-07-24T16:52:22Z I! Loaded inputs: http
2023-07-24T16:52:22Z I! Loaded aggregators:
2023-07-24T16:52:22Z I! Loaded processors:
2023-07-24T16:52:22Z I! Loaded secretstores:
2023-07-24T16:52:22Z I! Loaded outputs: influxdb_v2
2023-07-24T16:52:22Z I! Tags enabled: host=openplotter
2023-07-24T16:52:22Z D! [agent] Initializing plugins
2023-07-24T16:52:22Z D! [agent] Connecting outputs
2023-07-24T16:52:22Z D! [agent] Attempting connection to [outputs.influxdb_v2]
2023-07-24T16:52:22Z D! [agent] Successfully connected to outputs.influxdb_v2
2023-07-24T16:52:22Z D! [agent] Starting service inputs
2023-07-24T16:52:22Z D! [agent] Stopping service inputs
2023-07-24T16:52:22Z D! [agent] Input channel closed
2023-07-24T16:52:22Z I! [agent] Hang on, flushing any cached metrics before shutdown
2023-07-24T16:52:22Z D! [outputs.influxdb_v2] Wrote batch of 1 metrics in 53.092468ms
2023-07-24T16:52:22Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-07-24T16:52:22Z I! [agent] Stopping running outputs
2023-07-24T16:52:22Z D! [agent] Stopped Successfully
config file is:
[[inputs.http]]
interval = “5s”
name_override = “self.environment.time”
urls = [“http://localhost:3000/signalk/v1/api/vessels/self/environment/time”]
method = “GET”
success_status_codes = [200]
json_time_key = “timestamp”
json_time_format = “RFC3339”
tag_keys = [“$source”]
data_format = “json”
[[outputs.influxdb_v2]]
flush_interval = “5s”
urls = [“http://localhost:8086”]
token = “rv5lyMpqn90wW71ldPmipYsrEB5oS834KjjD8hdP378KcZBA4V9JvR6TbRPBheP9-IWcl79BD1_3M1hva8eaEA==”
organization = “Idunn”
bucket = “idunn”
Accessing endpoint for the GET:
“meta”: {
“description”: “A time reference for the vessel. All clocks on the vessel dispaying local time should use the timezone offset here. If a timezoneRegion is supplied the timezone must also be supplied. If timezoneRegion is supplied that should be displayed by UIs in preference to simply timezone. ie 12:05 (Europe/London) should be displayed in preference to 12:05 (UTC+01:00)”
“value”: “12:35”,
“$source”: “signalk-datetime”,
“timestamp”: “2023-07-24T15:35:49.561Z”
Why same config works like a charm for numeric values? any hep is more than welcome, thx!
