I’m trying to match the following pattern:
2018-08-09 22:05:15,023 [11] INFO method=GET - code=OK - url=AN URL (localhost:10520/WebAPI/api/Template/templates) - milliseconds=546
I got the error of grok not matching so started to go token by token as suggested, so I started with the date:
I used this pattern:
patterns = [“%{CUSTOM_LOG_DATE}”]
custom_patterns = ‘’’
CUSTOM_LOG_DATE %{YEAR}-%{MONTHNUM}-%{MONTHDAY} %{TIME}
Also doesn’t work.
2018-08-10T10:49:28Z I! Agent Config: Interval:10s, Quiet:false, Hostname:“DESKTOP”, Flush Interval:10s
2018-08-10T10:49:28Z D! Grok no match found for: “2018-08-09 21:04:46,766”
2018-08-10T10:49:28Z D! Grok no match found for: “2018-08-10 22:04:46,999”
2018-08-10T10:49:28Z D! Grok no match found for: “2018-08-11 23:04:46,999”
Even though the grok debugger states it should https://grokdebug.herokuapp.com/
also Test grok patterns states that it matches
I’m using 1.7.3, looks like the issue with the actual timestamp is resolved in 1.8
Any assistance would be reaaaalllyyy appreciated.
