Hi @everyone.
We are trying to get data from the kube_inventory plugin, but just getting only one measurement (kubernetes_node).
I’ve deployed as a deployment on the “monitoring” namespace accesign to the kubernetes.default.svc API as described in (Access Clusters Using the Kubernetes API | Kubernetes)
This is my configmap
apiVersion: v1
kind: ConfigMap
metadata:
namespace: monitoring
labels:
k8s-app: telegraf-ki
data:
telegraf.conf: |+
[global_tags]
env = "$ENV"
[agent]
interval = "60s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
debug = true
quiet = false
logfile = ""
omit_hostname = true
[[outputs.influxdb]]
urls = ["$MONITOR_HOST"]
database = "$MONITOR_DATABASE"
timeout = "5s"
username = "$MONITOR_USERNAME"
password = "$MONITOR_PASSWORD"
user_agent = "telegraf_ki_k8s"
[[outputs.file]]
files = ["stdout"]
data_format = "influx"
[[inputs.kube_inventory]]
url = "https://kubernetes.default.svc"
bearer_token = "/var/run/secrets/kubernetes.io/serviceaccount/token"
insecure_skip_verify = true
And this my output log on stdout, where you can see 1 measurement and no errors, but none about
- daemonsets
- deployments
- persistentvolumes
- persistentvolumeclaims
- pods (containers)
- statefulsets
As described in telegraf/plugins/inputs/kube_inventory at master · influxdata/telegraf · GitHub
2019-06-21T06:53:55Z I! Starting Telegraf 1.11.0
2019-06-21T06:53:55Z I! Using config file: /etc/telegraf/telegraf.conf
2019-06-21T06:53:55Z I! Loaded inputs: kube_inventory
2019-06-21T06:53:55Z I! Loaded aggregators:
2019-06-21T06:53:55Z I! Loaded processors:
2019-06-21T06:53:55Z I! Loaded outputs: influxdb file
2019-06-21T06:53:55Z I! Tags enabled: env=clusterA
2019-06-21T06:53:55Z I! [agent] Config: Interval:1m0s, Quiet:false, Hostname:"", Flush Interval:10s
2019-06-21T06:53:55Z D! [agent] Connecting outputs
2019-06-21T06:53:55Z D! [agent] Attempting connection to output: influxdb
2019-06-21T06:53:55Z W! [outputs.influxdb] when writing to [http://10.0.2.4:9096]: database "caas_metrics2" creation failed: 400 Bad Request
2019-06-21T06:53:55Z D! [agent] Successfully connected to output: influxdb
2019-06-21T06:53:55Z D! [agent] Attempting connection to output: file
2019-06-21T06:53:55Z D! [agent] Successfully connected to output: file
2019-06-21T06:53:55Z D! [agent] Starting service inputs
2019-06-21T06:54:10Z D! [outputs.file] wrote batch of 1 metrics in 127.495µs
2019-06-21T06:54:10Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
kubernetes_node,env=clusterA,node_name=kubetst01 capacity_memory_bytes=6133161984i,capacity_pods=110i,capacity_cpu_cores=1i,allocatable_memory_bytes=6028304384i,allocatable_pods=110i,allocatable_cpu_cores=1i 1561100040000000000
2019-06-21T06:54:10Z D! [outputs.influxdb] wrote batch of 1 metrics in 55.832466ms
2019-06-21T06:54:10Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:20Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:30Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:30Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:40Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:50Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:54:50Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:00Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
kubernetes_node,env=clusterA,node_name=kubetst01 allocatable_pods=110i,capacity_cpu_cores=1i,capacity_memory_bytes=6133161984i,capacity_pods=110i,allocatable_cpu_cores=1i,allocatable_memory_bytes=6028304384i 1561100100000000000
2019-06-21T06:55:10Z D! [outputs.file] wrote batch of 1 metrics in 136.117µs
2019-06-21T06:55:10Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:10Z D! [outputs.influxdb] wrote batch of 1 metrics in 151.65821ms
2019-06-21T06:55:10Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:20Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:30Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:30Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:40Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:50Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:55:50Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:00Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
kubernetes_node,env=clusterA,node_name=kubetst01 allocatable_cpu_cores=1i,allocatable_memory_bytes=6028304384i,allocatable_pods=110i,capacity_cpu_cores=1i,capacity_memory_bytes=6133161984i,capacity_pods=110i 1561100160000000000
2019-06-21T06:56:10Z D! [outputs.file] wrote batch of 1 metrics in 72.724µs
2019-06-21T06:56:10Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:10Z D! [outputs.influxdb] wrote batch of 1 metrics in 36.22681ms
2019-06-21T06:56:10Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:20Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:30Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:30Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:40Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:50Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:56:50Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:00Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
kubernetes_node,env=clusterA,node_name=kubetst01 capacity_cpu_cores=1i,capacity_memory_bytes=6133161984i,capacity_pods=110i,allocatable_cpu_cores=1i,allocatable_memory_bytes=6028304384i,allocatable_pods=110i 1561100220000000000
2019-06-21T06:57:10Z D! [outputs.file] wrote batch of 1 metrics in 70.295µs
2019-06-21T06:57:10Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:10Z D! [outputs.influxdb] wrote batch of 1 metrics in 34.21583ms
2019-06-21T06:57:10Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:20Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:20Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:30Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:30Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:40Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:40Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:50Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:57:50Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:58:00Z D! [outputs.influxdb] buffer fullness: 0 / 10000 metrics.
2019-06-21T06:58:00Z D! [outputs.file] buffer fullness: 0 / 10000 metrics.
I’ve just test changing serviceaccount as described Here (telegraf/plugins/inputs/kube_inventory at master · influxdata/telegraf · GitHub) and also with cluster-admin roles , in both cases with the same result.
Any idea on how to fix it?
These are my lab versions
$ kubectl cluster-info
Kubernetes master is running at https://10.0.2.15:6443
KubeDNS is running at https://10.0.2.15:6443/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
Metrics-server is running at https://10.0.2.15:6443/api/v1/namespaces/kube-system/services/https:metrics-server:/proxy
To further debug and diagnose cluster problems, use 'kubectl cluster-info dump'.
$ kubectl get nodes
NAME STATUS ROLES AGE VERSION
kubetst01 Ready master 279d v1.11.3
