Hello all,
I am using opcua telegraf plugin to collect data but for some reason based on telegraf logs it keeps disconnecting from opcua and connectes again. this happens in random time interval.
This are the telegraf logs that i’m getting.
2023-04-11T04:37:00Z D! [inputs.opcua] Disconnecting from OPC UA Server
2023-04-11T04:37:00Z E! [inputs.opcua] Error in plugin: RegisterNodes Read failed: The session id is not valid. StatusBadSessionIDInvalid (0x80250000)
2023-04-11T04:38:00Z D! [inputs.opcua] Connecting OPC UA Client to server
2023-04-11T04:38:00Z D! [inputs.opcua] Configuring OPC UA connection options
2023-04-11T04:38:00Z W! [inputs.opcua] Failed to load certificate: open /etc/telegraf/cert.pem: The system cannot find the path specified.
2023-04-11T04:38:00Z D! [inputs.opcua] security policy from configuration Profile Reporting Links
2023-04-11T04:38:00Z D! [inputs.opcua] User cares about both the policy (Profile Reporting Links) and security mode (MessageSecurityModeNone)
2023-04-11T04:38:00Z D! [inputs.opcua] Server has 1 endpoints
2023-04-11T04:38:00Z D! [inputs.opcua] Evaluating endpoint opc.tcp://10.0.0.5:49320, policy Profile Reporting Links, mode MessageSecurityModeNone, level 16
2023-04-11T04:38:00Z D! [inputs.opcua] Security policy and mode found. Using server endpoint opc.tcp://10.0.0.5:49320 for security. Policy Profile Reporting Links
2023-04-11T04:38:00Z D! [inputs.opcua] Connected to OPC UA Server
This keeps happening and i am losing data within that time interval.
can some on help me with this. Thanks
