Using Telegraf 1.20 but the issue also presents in other versions. I was using a version from early 2020, updated to see if would improve and nothing.
Screencapture of the issue. Telegraf CPU Spikes - YouTube
# GLOBAL CONFIG #
# Global tags can be specified here in key="value" format.
[global_tags]
system_type = "####################"
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 100000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
debug = false
quiet = false
logfile = "/Program Files/Telegraf/telegraf.log"
hostname = "$COMPUTERNAME.$DOMAINFQDN"
omit_hostname = false
# OUTPUTS #
# Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
urls = ["http://#################:8086"]
database = "telegraf"
retention_policy = ""
write_consistency = "any"
timeout = "10s"
# INPUTS #
[[inputs.system]]
[[inputs.exec]]
commands = ['''PowerShell.exe -Command "$version = (Get-ItemProperty HKLM:\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\* | Where-Object DisplayName -like "################").DisplayVersion; $buildNumber = (Get-Content -Path \"${ENV:PROGRAMFILES(x86)}\######\#########\BuildInfo#######.txt\").Split(\":\")[1].Trim(); Write-Host \"V\"$version.Split(\".\")[0]\" R\"$version.Split(\".\")[1]\".\"$version.Split(\".\")[2]\".\"$version.Split(\".\")[3]\" BUILD \"$buildNumber -Separator \"\""''']
name_override = "softwareVersion"
interval = "120s"
data_format = "value"
data_type = "string"
[inputs.exec.tags]
type = "application"
[[inputs.win_perf_counters]]
[[inputs.win_perf_counters.object]]
# Processor usage, alternative to native, reports on a per core.
ObjectName = "Processor"
Instances = ["*"]
Counters = [
"% Idle Time",
"% Interrupt Time",
"% Privileged Time",
"% User Time",
"% Processor Time",
"% DPC Time",
"DPC Rate",
Measurement = "win_cpu"
IncludeTotal=true
ObjectName = "Process"
Instances = ["*"]
Counters = [
"Working Set - Private",
"IO Read Operations/sec",
"IO Write Operations/sec",
"IO Data Operations/sec",
"IO Read Bytes/sec",
"IO Write Bytes/sec",
"Handle Count",
"Private Bytes",
"Working Set",
"Working Set Peak",
"% Processor Time",
Measurement = "win_process"
IncludeTotal=true
# Disk times and queues
ObjectName = "LogicalDisk"
Instances = ["*"]
Counters = [
"% Idle Time",
"% Disk Time",
"% Disk Read Time",
"% Disk Write Time",
"% User Time",
"Current Disk Queue Length",
"% Free Space",
"Free Megabytes",
Measurement = "win_disk"
IncludeTotal=true
ObjectName = "PhysicalDisk"
Instances = ["*"]
Counters = [
"Disk Read Bytes/sec",
"Disk Write Bytes/sec",
"Avg. Disk sec/Read",
"Avg. Disk sec/Write",
"Split IO/sec",
"Disk Reads/sec",
"Disk Writes/sec",
"% Disk Time",
"% Disk Read Time",
Measurement = "win_physdisk"
ObjectName = "Network Interface"
Instances = ["*"]
Counters = [
"Bytes Received/sec",
"Bytes Sent/sec",
"Bytes Total/sec",
"Packets Received/sec",
"Packets Sent/sec",
"Packets Received Discarded",
"Packets Outbound Discarded",
"Packets Received Errors",
"Packets Outbound Errors",
Measurement = "win_net"
ObjectName = "System"
Counters = [
"Context Switches/sec",
"System Calls/sec",
"Processor Queue Length",
"System Up Time",
"Processes",
"Threads",
Instances = ["------"]
Measurement = "win_system"
IncludeTotal=true
ObjectName = "Memory"
Counters = [
"Available Bytes",
"Cache Faults/sec",
"Demand Zero Faults/sec",
"Page Faults/sec",
"Pages/sec",
"Page Reads/sec",
"Page Writes/sec",
"Transition Faults/sec",
"Pool Nonpaged Bytes",
"Pool Paged Bytes",
"Cache Bytes",
"Standby Cache Reserve Bytes",
"Standby Cache Normal Priority Bytes",
"Standby Cache Core Bytes",
"% Committed Bytes In Use",
# Use 6 x - to remove the Instance bit from the query.
Measurement = "win_mem"
IncludeTotal=true
ObjectName = "Paging File"
Counters = [
"% Usage",
"% Usage Peak",
Instances = ["_Total"]
Measurement = "win_swap"
ObjectName = "Thread"
Instances = ["*"]
Counters = [
"Thread State",
"Thread Wait Reason",
"ID Process",
"ID Thread",
"Prority Base",
"Prority Current",
Measurement = "win_thread"
[[inputs.net_response]]
protocol = "tcp"
address = "localhost:443"
# timeout = "1s"
# read_timeout = "1s"
fielddrop = ["result_type", "string_found"]
[[inputs.jolokia2_agent]]
urls = ["http://localhost:8080/jolokia"]
name_prefix = "tomcat_"
### JVM Generic
[[inputs.jolokia2_agent.metric]]
name = "OperatingSystem"
mbean = "java.lang:type=OperatingSystem"
paths = ["ProcessCpuLoad","SystemLoadAverage","SystemCpuLoad"]
name = "jvm_runtime"
mbean = "java.lang:type=Runtime"
paths = ["Uptime"]
name = "jvm_memory"
mbean = "java.lang:type=Memory"
paths = ["HeapMemoryUsage", "NonHeapMemoryUsage", "ObjectPendingFinalizationCount"]
name = "jvm_garbage_collector"
mbean = "java.lang:name=*,type=GarbageCollector"
paths = ["CollectionTime", "CollectionCount"]
tag_keys = ["name"]
name = "jvm_memory_pool"
mbean = "java.lang:name=*,type=MemoryPool"
paths = ["Usage", "PeakUsage", "CollectionUsage"]
tag_keys = ["name"]
tag_prefix = "pool_"
### TOMCAT
name = "GlobalRequestProcessor"
mbean = "Catalina:name=*,type=GlobalRequestProcessor"
paths = ["requestCount","bytesReceived","bytesSent","processingTime","errorCount"]
tag_keys = ["name"]
name = "JspMonitor"
mbean = "Catalina:J2EEApplication=*,J2EEServer=*,WebModule=*,name=jsp,type=JspMonitor"
paths = ["jspReloadCount","jspCount","jspUnloadCount"]
tag_keys = ["J2EEApplication","J2EEServer","WebModule"]
name = "ThreadPool"
mbean = "Catalina:name=*,type=ThreadPool"
paths = ["maxThreads","currentThreadCount","currentThreadsBusy"]
tag_keys = ["name"]
name = "Servlet"
mbean = "Catalina:J2EEApplication=*,J2EEServer=*,WebModule=*,j2eeType=Servlet,name=*"
paths = ["processingTime","errorCount","requestCount"]
tag_keys = ["name","J2EEApplication","J2EEServer","WebModule"]
name = "Cache"
mbean = "Catalina:context=*,host=*,name=Cache,type=WebResourceRoot"
paths = ["hitCount","lookupCount"]
tag_keys = ["context","host"]
name = "Server"
mbean = "Catalina:type=Server"
paths = ["serverInfo","serverBuilt"]
