Hello Team,
Trying to use telegraf for forwarding telemetry metrics from hashicvault to Splunk, telegraf able to connect to splunk but failing to inject logs.
2021-03-08T16:40:55Z D! Can not parse value: 13 days, 21:26 for key: uptime_format
2021-03-08T16:40:55Z D! Can not parse value: 13 days, 21:27 for key: uptime_format
2021-03-08T16:40:55Z D! [outputs.http] Buffer fullness: 149 / 100000 metrics
2021-03-08T16:40:55Z E! [agent] Error writing to outputs.http: when writing to [https://http-inputs-XXXdevstests.splunkcloud.com:443/services/collector/event] received status code: 400
Which input plugin is used?
Which output plugin is used?
Please post the relevant parts of the telegraf config file here in markdown format:
```toml
put you config code snippets here
[quote=“Franky1, post:2, topic:18765”]
[global_tags]
index="vault-metrics"
datacenter = "us-east-2"
role = "vault-server"
cluster = "http://XXXX.abc.123.com:8201"
# Agent options around collection interval, sizes, jitter and so on
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = ""
omit_hostname = false
# An output plugin that can transmit metrics over HTTP to Splunk
# You must specify a valid Splunk HEC token as the Authorization value
[[outputs.http]]
url = "https://http-inputs-XXXdevstests.splunkcloud.com:443/services/collector/event"
data_format="splunkmetric"
splunkmetric_hec_routing=true
[outputs.http.headers]
Content-Type = "application/json"
Authorization = "Splunk XXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXX"
I suspect (based on the 400 response) that something is wrong with either the Splunk configuration in outputs.http
of Telegraf or the (input) configuration in Splunk itself.
https://docs.influxdata.com/telegraf/v1.17/data_formats/output/splunkmetric/
