Hi i’am new in docker-monitoring and i choose influx to monitor my docker !
i have installed telegraf on a container and i want to know if i can display metrics of all containers using this telegraf !
this is my ‘‘docker ps’’
some hhelp please
Hello @Annonyme1,
Welcome!
Yes, you can. You can gather the following metrics out of the box: I can gather the following metrics out of the box:
Here is an example of some output from the docker telegraf input plugin as seen here:
docker,engine_host=debian-stretch-docker,server_version=17.09.0-ce n_containers=6i,n_containers_paused=0i,n_containers_running=1i,n_containers_stopped=5i,n_cpus=2i,n_goroutines=41i,n_images=2i,n_listener_events=0i,n_used_file_descriptors=27i 1524002041000000000
docker,engine_host=debian-stretch-docker,server_version=17.09.0-ce,unit=bytes memory_total=2101661696i 1524002041000000000
docker_container_mem,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,engine_host=debian-stretch-docker,server_version=17.09.0-ce active_anon=8327168i,active_file=2314240i,cache=27402240i,container_id="adc4ba9593871bf2ab95f3ffde70d1b638b897bb225d21c2c9c84226a10a8cf4",hierarchical_memory_limit=9223372036854771712i,inactive_anon=0i,inactive_file=25088000i,limit=2101661696i,mapped_file=20582400i,max_usage=36646912i,pgfault=4193i,pgmajfault=214i,pgpgin=9243i,pgpgout=520i,rss=8327168i,rss_huge=0i,total_active_anon=8327168i,total_active_file=2314240i,total_cache=27402240i,total_inactive_anon=0i,total_inactive_file=25088000i,total_mapped_file=20582400i,total_pgfault=4193i,total_pgmajfault=214i,total_pgpgin=9243i,total_pgpgout=520i,total_rss=8327168i,total_rss_huge=0i,total_unevictable=0i,total_writeback=0i,unevictable=0i,usage=36528128i,usage_percent=0.4342225020025297,writeback=0i 1524002042000000000
docker_container_cpu,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,cpu=cpu-total,engine_host=debian-stretch-docker,server_version=17.09.0-ce container_id="adc4ba9593871bf2ab95f3ffde70d1b638b897bb225d21c2c9c84226a10a8cf4",throttling_periods=0i,throttling_throttled_periods=0i,throttling_throttled_time=0i,usage_in_kernelmode=40000000i,usage_in_usermode=100000000i,usage_percent=0,usage_system=6394210000000i,usage_total=117319068i 1524002042000000000
docker_container_cpu,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,cpu=cpu0,engine_host=debian-stretch-docker,server_version=17.09.0-ce container_id="adc4ba9593871bf2ab95f3ffde70d1b638b897bb225d21c2c9c84226a10a8cf4",usage_total=20825265i 1524002042000000000
docker_container_cpu,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,cpu=cpu1,engine_host=debian-stretch-docker,server_version=17.09.0-ce container_id="adc4ba9593871bf2ab95f3ffde70d1b638b897bb225d21c2c9c84226a10a8cf4",usage_total=96493803i 1524002042000000000
docker_container_net,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,engine_host=debian-stretch-docker,network=eth0,server_version=17.09.0-ce container_id="adc4ba9593871bf2ab95f3ffde70d1b638b897bb225d21c2c9c84226a10a8cf4",rx_bytes=1576i,rx_dropped=0i,rx_errors=0i,rx_packets=20i,tx_bytes=0i,tx_dropped=0i,tx_errors=0i,tx_packets=0i 1524002042000000000
docker_container_blkio,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,device=254:0,engine_host=debian-stretch-docker,server_version=17.09.0-ce container_id="adc4ba9593871bf2ab95f3ffde70d1b638b897bb225d21c2c9c84226a10a8cf4",io_service_bytes_recursive_async=27398144i,io_service_bytes_recursive_read=27398144i,io_service_bytes_recursive_sync=0i,io_service_bytes_recursive_total=27398144i,io_service_bytes_recursive_write=0i,io_serviced_recursive_async=529i,io_serviced_recursive_read=529i,io_serviced_recursive_sync=0i,io_serviced_recursive_total=529i,io_serviced_recursive_write=0i 1524002042000000000
docker_container_health,container_image=telegraf,container_name=zen_ritchie,container_status=running,container_version=unknown,engine_host=debian-stretch-docker,server_version=17.09.0-ce failing_streak=0i,health_status="healthy" 1524007529000000000
docker_swarm,service_id=xaup2o9krw36j2dy1mjx1arjw,service_mode=replicated,service_name=test tasks_desired=3,tasks_running=3 1508968160000000000
Could you guide me with the steps to follow?
also need a similar guidance. if you do find any please update. thanks
