Could someone please help me regarding converts the integer into string in order to display the data in InfluxDB. Currently I am getting error in inlufluxDB as “unsupported input type for mean aggregate: string”
I posted the output in below whilst execute snmpwalk.
telegraf.conf////////
[[inputs.snmp.table.field]]
oid = “AVAYA-AURA-CM-MIB::avCmStatusSigGrp”
name = “Avaya-StatusSigGrp”
TestServer#snmpwalk -v 2c -c GrafanaTest 101.102.XXX.XX AVAYA-AURA-CM-MIB::avCmStatusSigGrp
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.59 = INTEGER: 59
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.60 = INTEGER: 60
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.98 = INTEGER: 98
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.99 = INTEGER: 99
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.100 = INTEGER: 100
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.300 = INTEGER: 300
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.350 = INTEGER: 350
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpNumber.400 = INTEGER: 400
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.15 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.20 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.22 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.25 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.30 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.31 = STRING: h.323
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.40 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.41 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.50 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.52 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.53 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.54 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.55 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.56 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.57 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.58 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.59 = STRING: isdn-pri
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.60 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.98 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.99 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.100 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.300 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.350 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpType.400 = STRING: sip
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.15 = STRING: out-of-service
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.20 = STRING: out-of-service
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.22 = STRING: in-service
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.25 = STRING: out-of-service
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.30 = STRING: out-of-service
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.31 = STRING: far-end bypass
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.40 = STRING: out-of-service
AVAYA-AURA-CM-MIB::avCmStatusSigGrpGrpState.41 = STRING: out-of-service
