I have read through the docs, blogs and other forums and have to be close on my telegraf.conf file here. If someone has asked/answered this before please point me to it.
I have streaming telemetry data coming into a host from a Juniper virtual switch in UDP / protobuf format. I can capture the data using nc and decode it using protoc:
protoc --decode TelemetryStream port.proto -I /usr/include/protos -I /usr/include/google/protobuf < /tmp/data.gpb > /tmp/data.json
cat /tmp/data.json
system_id: "ST-Justin:10.55.60.125"
component_id: 0
sub_component_id: 0
sensor_name: "ROUTER-INF:/junos/system/linecard/interface/:/junos/system/linecard/interface/:PFE"
sequence_number: 103837
timestamp: 1719150965216
version_major: 1
version_minor: 1
enterprise {
[juniperNetworks] {
[port.jnpr_interface_ext] {
interface_stats {
if_name: "ge-0/0/0"
init_time: 1718625895
snmp_if_index: 527
egress_queue_info {
queue_number: 0
packets: 0
bytes: 0
tail_drop_packets: 0
rl_drop_packets: 0
rl_drop_bytes: 0
red_drop_packets: 0
red_drop_bytes: 0
avg_buffer_occupancy: 0
cur_buffer_occupancy: 0
peak_buffer_occupancy: 0
allocated_buffer_size: 0
<snip>
Here is my current telegraf.conf file:
[global_tags]
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = "0s"
debug = true
omit_hostname = true
[[inputs.socket_listener]]
service_address = "udp://:2000"
data_format = "xpath_protobuf"
xpath_protobuf_file = "port.proto"
xpath_protobuf_type = "TelemetryStream"
xpath_print_document = true
xpath_native_types = false
xpath_protobuf_import_paths = ["/usr/include/protos","/usr/include/google/protobuf/"]
The resulting XML doc that is dumped by debug is:
grep xml /var/log/syslog
Jun 26 05:22:30 Juniper-ST-Dial-Out telegraf[201640]: 2024-06-26T15:22:30Z D! [parsers.xpath_protobuf::file] XML document equivalent: "<?xml version=\"1.0\"?><system_id>ST-Justin:10.55.60.125</system_id><component_id>0</component_id><version_major>1</version_major><version_minor>1</version_minor><sub_component_id>0</sub_component_id><sensor_name>ROUTER-INF:/junos/system/linecard/interface/:/junos/system/linecard/interface/:PFE</sensor_name><sequence_number>103837</sequence_number><timestamp>1719150965216</timestamp><enterprise></enterprise>"
For some reason, I am not seeing all the data in the enterprise part of the tree in that output like I do when I use nc and protoc to grab the data.
