Could I use “net_response” input plugin to check the remote server port status [ up or down ] ?. Or is there any inputs plugin available to check it.
I’m trying to replace icinga with telegraf. Since I already using telegraf for usage metric. If its support remote server ports check also, then I can bring everything under same tools instead of depending on separate tool for each service.
