I have installed Telegraf and InfluxDB2 on a Kubernetes cluster. I have created a token on influxdb2 and configured telegraf with an output for the token and bucket. Telegraf has an mqtt consumer input. Telegraf is connecting to influxdb2 and the mqtt broker successfully, but when it processes a new mqtt message and tries to send the data to influxdb2 it reports an error “Failed to write metric (will be dropped: 404 Not Found): not found: bucket not found”. The bucket is set in the influxdb2 output and is correct. I have even created a token with all rights on all buckets to test, but it still can’t find the bucket. Does anyone have any pointers on how I can troubleshoot this? The debug level log doesn’t even say which bucket it’s trying to find, so I can’t see if it’s just a config problem. Any help greatly appreciated. Logs below:
2022-02-21T19:31:24Z I! Starting Telegraf 1.21.4
2022-02-21T19:31:24Z I! Using config file: /etc/telegraf/telegraf.conf
2022-02-22T08:31:24+13:00 I! Loaded inputs: mqtt_consumer (2x)
2022-02-22T08:31:24+13:00 I! Loaded aggregators:
2022-02-22T08:31:24+13:00 I! Loaded processors:
2022-02-22T08:31:24+13:00 I! Loaded outputs: influxdb_v2 (2x)
2022-02-22T08:31:24+13:00 I! Tags enabled: host=telegraf-c9fc696bc-qbsjg
2022-02-22T08:31:24+13:00 I! [agent] Config: Interval:10s, Quiet:false, Hostname:"telegraf-c9fc696bc-qbsjg", Flush Interval:10s
2022-02-22T08:31:24+13:00 D! [agent] Initializing plugins
2022-02-22T08:31:24+13:00 D! [agent] Connecting outputs
2022-02-22T08:31:24+13:00 D! [agent] Attempting connection to [outputs.influxdb_v2]
2022-02-22T08:31:24+13:00 D! [agent] Successfully connected to outputs.influxdb_v2
2022-02-22T08:31:24+13:00 D! [agent] Starting service inputs
2022-02-22T08:31:24+13:00 I! [inputs.mqtt_consumer] Connected [hidden]
2022-02-22T08:31:24+13:00 D! [inputs.mqtt_consumer] Session found [hidden]
2022-02-22T08:32:34+13:00 E! [outputs.influxdb_v2] Failed to write metric (will be dropped: 404 Not Found): not found: bucket not found
2022-02-22T08:32:34+13:00 D! [outputs.influxdb_v2] Wrote batch of 2 metrics in 2.890752ms
