I need support, because unfortunately I can not find anything that helps me.
I have a working configurations in Telegraf which collects via JSON http GET some shelly data. For this I have created a configuration. With the setup instructions I could start it in the terminal and since then it works.
I just can’t do anything in the terminal because the script is running. telegraf --config http://192.168.1.190:8086/api/v2/telegrafs/09524001bcfe0000
I would like to use Telegraf for Modus and need an additional configuration. I can create another configuration. That works too.
But, how do I run both together? Or in other words, what is the best way to make multiple configurations work together?
Hello @Daniel_E,
You can include multiple input configs in the same telegraf config.
Are you writing data from both inputs to the same InfluxDB instance?
You mean I can address multiple Config’s via a Telegraf.conf? If that works that would be good.
For structuring I find several config files easier. And if I e.g. with extensions of the config file a change make, certain Configs start or stop. so like a service?
Is it possible to have a config with opcua.input + influx2.output and another config with opcua.input + influx2.output?
I want read data from 2 or more opcua devices and write it to one influx server, but multiple buckets.
