Telegraf : agent] Error writing to output [influxdb]: could not write any address
I am able to connect to my influxdb instance from telegraf instance but when i run telegraf , it gives this error:
[agent] Error writing to output [influxdb]: could not write any address
2019-01-21T10:52:52Z E! [outputs.influxdb] when writing to [http://10.54.28.12:8086]: 411 Length Required
2019-01-21T10:52:52Z E! [agent] Error writing to output [influxdb]: could not write any address
What does this mean?
With my conf file the database is getting created but m not able to write sois this memory issue?
I haven’t seen this status code from InfluxDB before, what version of InfluxDB are you using and do you have any proxies between Telegraf and InfluxDB?
I also have same issue. Did you fix the issue?
