Hi all,
What is the way, in telegraf with modbus plugin, if i want to record all the metrics only if one metric exced a value ?
Thanks for all.
I believe that the main use case of telegraf is to collect all data add the conditional stuff on the query side.
At least that is how I use it, and its nice to be able to log and see everything.
however, you could do what you need using the staralark plugin:
Removing entire metric base on a field value. · Issue #3904 · influxdata/telegraf (github.com)
Ok, Thank you for all, i will try that.
