I have built next kind of solution that are using influxdb.
- I have installed “Influx CLI 2.6.1 (git: 61c5b4d) build_date: 2022-12-29T15:41:09Z” to my Rasberry pi.
- I use Influx task to send data from local influxdb to cloud influxdb, this task looks like this:
And this task is active:
Everything works as planned and it looks that Influxdb is the right tool for my purpose.
But now I notice one problem: when I copy the Rasperry image and start the whole system in the new Rasperry, then this task doesn’t automatically work anymore. When I look at the new Rasperry, the task is active but it is not executed. I found out a workaround for it: when I once Run this task manually, then it starts to work again and it will be executed every 1m, 20s offset.
So my question is: what happens when I copy the Rasperry image and start it from a new Rasperry? Is this a bug or a feature? Why is the task not executed automatically before I push (once) the Run task button? One interesting thing that I noticed too was that when I copied the image to a new Rasperry and I have a task that was executed every 5m (no offset) it started automatically and I don’t need to push the Run button at all.
