I am using telegraf from 3 nodes to send data to influxdb2.
I have setup a deadman check called uptime
which triggers to level crit
for a host if it is down for more than 10 min.
I am trying to create a table of all the hosts that are off (in state crit
) and ma using this query
from(bucket: "_monitoring")
|> filter(fn: (r) => r["_check_name"] == "uptime")
|> last()
|> filter(fn: (r) => r["_level"] == "crit")
However each line of output has its own table ID.
Any suggestions on how I can go about doing this or if there is some sort of template or other mechanism to achieve this would be very helpful.
Thanks,
Reshad
