While I was testing the syslog output, I noticed that when SIDs are greater than 32 characters, the output doesnot contain SIDs at all.
The telegraf output/input configuration is given below.
[[inputs.tail]]
from_beginning = true
files = ['/home/ec2-user/syslog.line']
data_format = "influx"
[[outputs.syslog]]
framing = "non-transparent"
trailer = "LF"
sdids = ["fce4b930-e7a4-4228-a05f-a33@41058"]
sdparam_separator = "_"
default_severity_code = 5
default_facility_code = 1
address = "tcp://logs-01.loggly.com:514"
#tls_cert = "/etc/rsyslog.d/keys/ca.d/logs-01.loggly.com_sha12.crt"
namepass = ['loggly_logs']
tagexclude = ['dc', 'env', 'host', 'path', 'qcinstance']
When my input file have following entry
loggly_logs,appname=Woohoo-Container fce4b930-e7a4-4228-a05f-a33@41058_tag=“Container”,msg=“Testing containers”
I can see in the tcpdump there are no Structured Datas in the packet
192.168.38.222.47956 > 52.24.177.168.514: Flags [P.], cksum 0xcdce (incorrect → 0x18db), seq 452503436:452503533, ack 2968423998, win 211, options [nop,nop,TS val 3089823145 ecr 607085399], length 97
0x0000: 4500 0095 50e0 4000 ff06 5d3b c0a8 26de E…P.@…];…&.
0x0010: 3418 b1a8 bb54 0202 1af8 a78c b0ee 8e3e 4…T…>
0x0020: 8018 00d3 cdce 0000 0101 080a b82a f5a9 …*…
0x0030: 242f 6357 3c31 333e 3120 3230 3230 2d30 $/cW<13>1.2020-0
0x0040: 342d 3137 5430 363a 3338 3a33 375a 2069 4-17T06:38:37Z.i
0x0050: 702d 3139 322d 3136 382d 3338 2d32 3232 p-192-168-38-222
0x0060: 2057 6f6f 686f 6f2d 436f 6e74 6169 6e65 .Woohoo-Containe
0x0070: 7220 2d20 6c6f 6767 6c79 5f6c 6f67 7320 r.-.loggly_logs.
0x0080: 2d20 5465 7374 696e 6720 636f 6e74 6169 -.Testing.contai
0x0090: 6e65 7273 00 ners.
When I remove one character from the SDID like below
loggly_logs,appname=Woohoo-Container fce4b930-e7a4-4228-a05f-a33@1058_tag=“Container”,msg=“Testing containers”
I can see the structured data in the packet.
06:38:00.000912 IP (tos 0x0, ttl 255, id 33480, offset 0, flags [DF], proto TCP (6), length 198)
192.168.38.222.60514 > 75.101.233.97.514: Flags [P.], cksum 0x1d06 (incorrect → 0xf11a), seq 83451929:83452075, ack 4149530591, win 211, options [nop,nop,TS val 2413407202 ecr 801391507], length 146
0x0000: 4500 00c6 82c8 4000 ff06 dc1b c0a8 26de E…@…&.
0x0010: 4b65 e961 ec62 0202 04f9 6019 f754 cfdf Ke.a.b…`…T…
0x0020: 8018 00d3 1d06 0000 0101 080a 8fd9 abe2 …
0x0030: 2fc4 4393 3c31 333e 3120 3230 3230 2d30 /.C.<13>1.2020-0
0x0040: 342d 3137 5430 363a 3337 3a34 385a 2069 4-17T06:37:48Z.i
0x0080: 5b66 6365 3462 3933 302d 6537 6134 2d34 [fce4b930-e7a4-4
0x0090: 3232 382d 6130 3566 2d61 3333 4031 3035 228-a05f-a33@105
0x00a0: 3820 7461 673d 2243 6f6e 7461 696e 6572 8.tag="Container
0x00b0: 225d 2054 6573 7469 6e67 2063 6f6e 7461 "].Testing.conta
0x00c0: 696e 6572 7300 iners.
What I observed is when the length of SDID is less than 32 characters the structured data is present in the packet. When it exceeds 32 characters it is absent.
I have a 42 character long SDID. Is this a bug. Is there any workaround for this.
Thanks,
Robert
