Hello, I’m looking to copy data from an influxdb 2.0 instance to second central influx 2.0 instance. Has the subscriber service been replaced as I cannot find any documentation on this for 2.0?
Hello @Lewrs,
Welcome! Unfortunately, there isn’t really anything like that in v2 atm. However you can always configure telegraf to write to both instances. The eventual plan is that for v2
you can use a Flux query and from |> to
but were to
goes to a different instance but that will work best for smaller more specific sets of data. There are some plans for bulk loading, but they’ve been deprioritized. As always, I encourage you to create an issue. Perhaps it should be more of a priority.
Thanks for the reply. Does telegraf queue measurements if the connection to V2 is lost for what ever reason?
Hello @Lewrs,
Yes. Metrics are kept in memory to the size or your metric_buffer_limit
, which is specified as a part of the agent configuration.
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
