I am trying to recreate an inner join with Kapacitor on a non time column, but so far I did not achieved that.
- I have two measurement tables T1 and T2, each with 3 columns: time, seq_no, and value.
- Sequence number (seq_no) is a unique column per table.
- The arrival rate of new samples per table is about 50 per second
- Maximum expected time interval (gap) between two rows in T1 and T2 with the same seq_no is a few seconds
I want to produce a third table T3 in the following way:
SELECT T1.value, T2.value
FROM T1
INNER JOIN T2 ON T1.seq_no = T2.seq_no;
There is a similar post here, but It didn’t answered my question.
This is what I have now:
var S1 = stream
|from()
.measurement('T1')
.groupBy('seq_no')
var S2 = stream
|from()
.measurement('T2')
.groupBy('seq_no')
S1
|join(S2)
.as('S1', 'S2')
.tolerance(10s)
.fill('null')
|where(lambda: "S1.seq_no" == "S2.seq_no")
|eval(lambda: "S1.seq_no", lambda: "S2.seq_no")
.as('s1', 's2')
|influxDBOut()
.database('dbname')
.buffer(2)
.measurement('join3')
Below is the output that I get. The problem with it is that I am seeing a single sample per minute or so, thus majority of samples in T1 and T2 are never being matched!
time s1 s2
1522941900000000000 3424253 3424253
1522941990000000000 3427773 3427773
1522942050000000000 3430717 3430717
1522942110000000000 3433461 3433461
1522942230000000000 3439337 3439337
1522942290000000000 3442237 3442237
1522942330000000000 3444125 3444125
1522942450000000000 3449709 3449709
Is there somehow I can increase the “matching” buffer between two tables, or redesign my query?
Thank you
