I’m trying to solve se following problem:
There is a measurement with the sample time of 30 seconds (Measurement 1), and there is a measurement with the sample time of 2 miliseconds (Measurement 2).
I need to join this two streams together (in a tick script) to produce the output as in the figure. The Measurement 1 must be oversampled/repeated every time a point from Measurement 2 arrives.
I tried the following tick script:
var features = stream
|from()
.measurement('stdk_teste')
var models = stream
|from()
.measurement('trained_model')
var data = features
|join(models)
.tolerance(100ms)
|influxDBOut()
.database('testes_canonicos')
.measurement('joins')
But it is producing an output that is not what i want:
(Note the timestamps, they are 30s spaced, all the data that arrives every 2ms is getting lost)
Thanks,
Vittor
