Store custom functions?
is there a way to store a custom function in InfluxDB 2 like for example stored procedures / stored functions are stored in traditional SQL databases?
I mean, they are very neat when you use them multiple times in the same flux script - but if I need them in multiple different ones (which is mostly the case), I would have to duplicate their definition into each of them. Not so good.
If it is not possible, is there an include-capability or is this feature planned for the future?
Thanks,
Steven
Hello @Steven_Weiss,
Welcome!
Unfortunately there isn’t.
I wish there was.
You used to be able to contribute functions to Flux or you could add a function and recompile the binary but I wouldn’t recommend doing that.
