Starting Influx As A service
I am trying to set up influx as a service so it runs on start up.
I have tried
sudo service influx status
sudo service influxd status
sudo service influxdb status
And they all come back with
Unit influx.service could not be found…
Any Ideas?
Hello @mdavies23,
influxdb should run as a service by default.
Maybe try
sudo systemctl status influxdb
Or
journalctl -u influxdb -e
How did you install influxdb? What version?
If you didn’t use a package manager to install, then you’ll need to create the service file yourself.
