I was using the database and I decided to add SSL to my server. I am trying to find a solution to make it work… Does any of this make sense to you?
when I run from terminal I can access from http but I also get the following errors:
2022-10-15T23:14:15.054489Z info Starting {"log_id": "0dZUf9EG000", "service": "telemetry", "interval": "8h"}
2022-10-15T23:14:15.055354Z info Listening {"log_id": "0dZUf9EG000", "service": "tcp-listener", "transport": "http", "addr": ":8086", "port": 8086}
2022-10-15T23:14:17.447971Z info Unauthorized {"log_id": "0dZUf9EG000", "error": "token required"}
2022-10-15T23:14:25.290632Z error Unable to write gathered points {"log_id": "0dZUf9EG000", "service": "scraper", "scraper-name": "new target", "error": "database not found: 5550dc467dba55ad"}
2022-10-15T23:14:35.228724Z error Unable to write gathered points {"log_id": "0dZUf9EG000", "service": "scraper", "scraper-name": "new target", "error": "database not found: 5550dc467dba55ad"}
2022-10-15T23:14:45.269769Z error Unable to write gathered points {"log_id": "0dZUf9EG000", "service": "scraper", "scraper-name": "new target", "error": "database not found: 5550dc467dba55ad"}
^X^C2022-10-15T23:14:47.870851Z info Terminating precreation service {"log_id": "0dZUf9EG000", "service": "shard-precreation"}
2022-10-15T23:14:47.870925Z info Stopping {"log_id": "0dZUf9EG000", "service": "telemetry", "interval": "8h"}
2022-10-15T23:14:47.870905Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "HTTP server"}
2022-10-15T23:14:47.871202Z info Stopping {"log_id": "0dZUf9EG000", "service": "tcp-listener"}
2022-10-15T23:14:47.872127Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "scraper"}
2022-10-15T23:14:47.872228Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "task"}
2022-10-15T23:14:47.872722Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "query"}
2022-10-15T23:14:47.874028Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "replications"}
2022-10-15T23:14:47.874196Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "engine"}
2022-10-15T23:14:47.874267Z info Closing retention policy enforcement service {"log_id": "0dZUf9EG000", "service": "retention"}
2022-10-15T23:14:47.916886Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "sqlite"}
2022-10-15T23:14:47.917882Z info Stopping subsystem {"log_id": "0dZUf9EG000", "subsystem": "bolt"}
InfluxDB v2.4
letsencrypt .pem files
influxdb service files:
[Service]
User=influxdb
Group=influxdb
letsencrypt folder permissions:
drwx--x--x 3 root letsencrypt 4096 Oct 14 22:03 live
drwx--x--- 3 root letsencrypt 4096 Oct 14 22:03 archive
changed group after reading this guide
contents of /etc/influxdb/config.toml
bolt-path = "/var/lib/influxdb/influxd.bolt"
engine-path = "/var/lib/influxdb/engine"
https-enabled = true
https-certificate = "/etc/letsencrypt/live/<domain_name>/fullchain.pem"
https-private-key = "/etc/letsencrypt/live/<domain_name>/privkey.pem"
