Split data with same tag values into different tables
Let me explain my case
Lets assume, I have data with 2 tags and 1 field lets say name, age and score
Now i have 2 different scores for the same group key value which comes in the same table
Now i want to split them into separate tables to view these scores separately
How should i introduce a tag to say that we have two scores (create a new column to indicate the first and second score) and split them into separate tables
Please help me.
@jeyakumar You can add a row index column with a default value of 1 and then use cumulativeSum() to increment the index of each row in the table. For example, lets say you have the following table:
name age score
John 30 100
John 30 120
John 30 135
You would use map() to add a column that acts as a row index. In this example, I’ll just call the row index column, num:
data
    |> map(fn: (r) => ({r with num: 1}))
This produces the following table:
name age score num
John 30 100 1
John 30 120 1
John 30 135 1
Now use cumulativeSum() to cumulatively add values in the num column, essentially incrementing the row index:
data
    |> cumulativeSum(columns: ["num"])
This produces:
name age score num
John 30 100 1
John 30 120 2
John 30 135 3
Then if you add num to the group key, you’ll get a separate table for each distinct value of num:
data
    |> group(columns: ["name", "age", "num"])
Which gives you:
name age score num
John 30 100 1
name age score num
John 30 120 2
name age score num
John 30 135 3
Hopefully this helps.
Thanks, This helps a lot.
My case is a little more complex
lets say my data looks like
name age score table
Jacob 30 80 0
John 30 100 1
John 30 100 1
John 30 135 1
John 30 135 1
Scott 20 100 2
and i want to aggregate the scores of each group key values based on timestamp
The rows 2-5 has the same group key values but, row 2 and 3 has a timestamp which is different from rows 4 and 5
like
Jacob 30 80 0
John 30 100 1
John 30 135 2
Scott 20 100 3
_time is not part of the group key, and if i try to add that to group() the hours and minutes are different and splits each and every row
How can we do something like this?
