Splitting tag value
Maybe my approach is completely wrong, but I could find how to do it. I have multiple metrics from machines with following tags: role: “role1,role2”, role: “role1”, role:“role3,role4,role5” etc. and I am trying to process them to yield column with comma separated strings in the tag values like:
table    _value
_result
            role1
            role2
            role3
I get the tag values with the following code:
import "strings"
schema.tagValues(
  bucket: "telegraf",
  tag: "role",
|> some smart filter I could not wrap my head around
I know how to split the resulting string with strings.split(v: r._value, t: “,”), but it seems I can not find the right function to use over the generated array - If I use map it generates n columns with the comma separated values, which is not at all how I need it.
I appreciate if somebody can help me with that.
Hello @Ludmil_Stamboliyski,
Just to verify you want to convert a list to table in Flux programmatically?
I don’t think this is possible.
@scott can you confirm? Thank you.
@Ludmil_Stamboliyski I’m not sure I fully understand what you’re trying to do. Just to clarify, your result of schema.tagValues is similar to this?
_value
role1,role2
role1
role3,role4,role5
This is where I’m not sure exactly what you’re trying to do. When you say “column with comma separated strings,” do you mean a column that stores arrays of strings? If so, that isn’t possible in Flux. Arrays are a composite data type and columns cannot store a composite data type.
Can you explain the problem you’re trying to solve? There is probably another way around it.
Hi Scott - Here is the issue I am trying to solve: I have n servers - some of them have role X, some of them have role Z and some have multiple roles as X, Z and F. I am collecting my data with telegraf - so I have set a tag in global - role where I can store a single value - lets say role: X. I want to pass all roles a particular server has to influx and finally to grafana to use as variable selector in dashboards.
@Ludmil_Stamboliyski Cool, that definitely helps and I think I have a solution for you:
import "array"
import "strings"
tags = schema.tagValues(bucket: "telegraf", tag: "role")
// Concatenate all string values into a single comma-delimited string
tagsList =
    (tags
        |> reduce(
            identity: {_value: ""},
            fn: (r, accumulator) => ({_value: strings.trimLeft(v: accumulator._value + "," + r._value, cutset: ",")}),
        |> findColumn(fn: (key) => true, column: "_value"))[0]
// Split the tag value string on commas
tagsArr = strings.split(v: tagsList, t: ",")
// Convert each tag array element into a record
// Build a table from the array of records
// Dedup rows in the table
array.from(rows: tagsArr |> array.map(fn: (x) => ({_value: x})))
    |> unique(column: "_value")
Using your sample input data, this returns:
_value
role1
role2
role3
Wow, sincere thanks Scott, that works like a charm!
