I’m using telegraf with inputs.snmp to collect interfaces descriptions from cisco devices.
So far it is working ok but telegraf inyects all the decription into one tag type column and I would like to split the text by whitespaces and insert it into different tag type columns.
I know this descriptions will always have the exact same format.
Can I do this with Telegraf? Or do i have to work with Kapacitor directly?
Or this can’t be done either way?
Telegraf v1.5.2
Kapacitor v1.4.0
[[inputs.snmp]]
agents = [ “HOST” ]
timeout = “10s”
retries = 3
version = 2
community = “public”
[[inputs.snmp.table]]
name = “test_table”
index_as_tag = true
[[inputs.snmp.table.field]]
name = “pppSessTot”
oid = “1.3.6.1.4.1.9.9.786.1.2.1.1.5.2”
oid_index_suffix = “.1”
name = “description”
oid = “1.3.6.1.2.1.31.1.1.1.18”
is_tag = true
name = “ifaceName”
oid = “1.3.6.1.2.1.31.1.1.1.1”
name = “inbps”
oid = “1.3.6.1.2.1.31.1.1.1.6”
name = “outbps”
oid = “1.3.6.1.2.1.31.1.1.1.10”
Example output:
collector,index=435,description=Cisco Sub Interface Description ,agent_host=HOST ,host=grafana-srv pppSessTot=111,ifaceName=“InterfaceName”, inbps=4967476543061i,outbps=59008607926711i 1520963841000000000
I would like to have the tag value “CIsco Subs Interface Description” split into 4 different tag type columns
Any kind of help is more than welcome.
Regards
Marcelo
