[solved] Telegraf [[inputs.httpjson]] - add tags from sub-fields
How do I get the sub-fields with strings?
e.g. there is a gitlab_readiness with
   "shared_state_check" : {
      "status" : "ok"
   "redis_check" : {
      "status" : "ok"
   "fs_shards_check" : {
      "labels" : {
         "shard" : "default"
      "status" : "ok"
   "db_check" : {
      "status" : "ok"
   "cache_check" : {
      "status" : "ok"
   "queues_check" : {
      "status" : "ok"
As httpjson does only parse strings when added as tag_keys, I tried using
  tag_keys = [ "db_check_status" ]
  tag_keys = [ "db_check['status']" ]
However, the collection is always empty. What is the right syntax to get these fields?
Or do I have to wait for: Support JSON Path-like json parsing · Issue #1363 · influxdata/telegraf · GitHub ?
(edited: syntax)
Yeah, you will need 1363 to be able to parse this.
