I have data with timestamps ranging between Aug 23, 2017 00:00:00 to Aug 25, 2017 07:50:35 (displays OK in Grafana) and I’m trying to manually get aggregate data in the influx CLI. Why is it that using “time <= ” doesn’t work but “time <= now()” does?
A query with “start time” only:
> SELECT max(xmit_data),min(xmit_data),mean(xmit_data),stddev(xmit_data) FROM data WHERE hostname='mo79' AND time>=1503439200
time max min mean stddev
1503439200 6.80396506644e+11 2.94371092e+08 4.896211809081595e+11 3.0527230680530444e+11
A query with “end time” now():
> SELECT max(xmit_data),min(xmit_data),mean(xmit_data),stddev(xmit_data) FROM data WHERE hostname='mo79' AND time>1503439200 AND time<now()
1503439201 6.80396506644e+11 2.94371092e+08 4.896211809081595e+11 3.0527230680530444e+11
But this doesn’t work (empty result):
[influx@localhost ~]$ date +%s
1504624904
> SELECT max(xmit_data),min(xmit_data),mean(xmit_data),stddev(xmit_data) FROM data WHERE hostname='mo79' AND time>1503439200 AND time<1504624904
And it doesn’t seem to work for any timestamp between 1503439200 and now… Why ???
thanks
Marek
