Hi everyone,
I store metrics in influxdb every 5 minutes, sum them up by 5 minutes group, and get the difference between each subsequent value:
> SELECT difference(sum("COMP")) FROM "counts" WHERE time >= now() - 30m GROUP BY time(5m)
time difference
2018-10-09T14:30:00Z 7
2018-10-09T14:35:00Z 12
2018-10-09T14:40:00Z 29
2018-10-09T14:45:00Z 28
2018-10-09T14:50:00Z 13
I am able to narrow the timeframe of the results using operators on time:
> SELECT * FROM (SELECT difference(sum("COMP")) FROM "counts" WHERE time >= now() - 30m GROUP BY time(5m)) WHERE time <= '2018-10-09T14:40:00Z'
time difference
2018-10-09T14:25:00Z 12
> SELECT * FROM (SELECT difference(sum("COMP")) FROM "gtm_counts" WHERE time >= now() - 30m GROUP BY time(5m)) WHERE time >= '2018-10-09T14:40:00Z'
time difference
The full list of operators is provided in the documentation, unfortunately some of them don’t give the expected results, either returning nothing when an actual value should be returned, or even returning an error:
> SELECT * FROM (SELECT difference(sum("COMP")) FROM "counts" WHERE time >= now() - 30m GROUP BY time(5m)) WHERE time >= '2018-10-09T14:45:00Z'
time difference
2018-10-09T14:55:00Z 15
> SELECT * FROM (SELECT difference(sum("COMP")) FROM "counts" WHERE time >= now() - 30m GROUP BY time(5m)) WHERE time = '2018-10-09T14:45:00Z'
> SELECT * FROM (SELECT difference(sum("COMP")) FROM "counts" WHERE time >= now() - 30m GROUP BY time(5m)) WHERE time != '2018-10-09T14:45:00Z'
ERR: invalid time comparison operator: !=
Note that these operators works perfectly when I query my data without a subquery involved:
> SELECT "COMP" FROM "gtm_counts" WHERE time = '2018-10-09T15:30:05Z'
time COMP
2018-10-09T15:30:05Z 2
2018-10-09T15:30:05Z 1
What am I doing something wrong? I can easily filter on the difference value, but I need some enlightenment about the meaning and behavior of the time clause in the external query.
