Hello my name is Peter and I need your support.
Unfortunately, my english is not that good.
To the background. I have written a small program under PHP that omits my solar system.
As a database I have influx 1.7 and grafana for visualization.
I want to query from my database the best day of the month.
I have already tried many things but do not continue. Now I hope for you
The data is written to the table P-Solar every minute.
solar system.
Please can you clarify the word “omits”, as this does not make sense in that
context.
How do you define “best”?
SELECT “P-Solar” FROM “PV” WHERE …
We need to know how you as a human would calculate the “best day of the month”
in order to help you tell a computer to do it for you
This will show you the sum each day …
SELECT SUM(“P-Solar”) FROM “PV” WHERE time>‘2019-10-01’ GROUP BY TIME(1d)
You might need to change the WHERE clause to select the right measurements.
You might want to change the GROUP BY TIME to specify a timezone offset if you are not UTC, e.g.
GROUP BY TIME(1d,-3600s)
I don’t think you can have Influx automatically pick out the day with the highest sum, but at least you can get the sum for each day very easily.
If you are recording the kWH each day, and the inverter resets kWH to 0 each morning, and that value is stored as “E-Solar”, you can do this:
SELECT max(“E-Solar”) FROM “PV” WHERE time>‘2019-01-01’ GROUP BY TIME(1d)
