I’m attempting to collect TCP stats using the TCP-MIB::tcpConnTable data. It pulls the table as expected but all of the columns get inserted as tags, not fields. I tried to add the index_as_tag option but that didn’t fix it.
[[inputs.snmp.table]]
oid = "TCP-MIB::tcpConnTable"
index_as_tag = true
inherit_tags = ["sysName"]
Influx:
> show tag keys from tcpConnTable
tagKey
agent_host
host
index
sysName
tcpConnLocalAddress
tcpConnLocalPort
tcpConnRemAddress
tcpConnRemPort
I want the tcpConn columns as fields. I suppose I can manually specify them using inputs.snmp.table.field but the documentation says I shouldn’t have to and that they will be automatically added.
By default all columns of the SNMP table will be collected - it is not required to add a nested field for each column, only those which you wish to modify.
Any idea why each item is being seen as a tag instead of field?
