Dear All,
I am trying to use Kapaciotor for sending an email alert using chronograf. But it is not working for me. I can see alert events but I am not receiving the email
Kapcitor configuration:
[smtp]
#enabled = false
enabled = true
#host = “localhost”
host = “smtp.gmail.com”
#port = 25
port = 587
username = “xyz@gmail.com”
password = “xxxxxx”
From address for outgoing mail
from = “xyz@gmail.com”
List of default To addresses.
to = [“oncall@example.com”]
to = [“test@gmail.com”]
Skip TLS certificate verify when connecting to SMTP server
no-verify = false
Close idle connections after timeout
idle-timeout = “300s”
If true the all alerts will be sent via Email
without explicitly marking them in the TICKscript.
global = false
Only applies if global is true.
Sets all alerts in state-changes-only mode,
meaning alerts will only be sent if the alert state changes.
state-changes-only = false
Things tried:
- After configuration change chronograf, kapacitor, telegraf and InfluxDB service is restarted.
- Since I am using gmail, Less secure app is turned ON.
- In alert log I am not seeing any event specific to SMTP
Log configuration:
[logging]
# Destination for logs
# Can be a path to a file or ‘STDOUT’, ‘STDERR’.
file = “/var/log/kapacitor/kapacitor.log”
# Logging level can be one of:
# DEBUG, INFO, ERROR
# HTTP logging can be disabled in the [http] config section.
level = “DEBUG”
Still It is not working. Please let me know what is wrong in my configuration or setup.
Thanks & Regards
Varun
