I am new to InfluxDB and I am trying to compare the performance of MariaDB and InfluxDB 2.0. Therefore I perform a benchmark of about 350.000 rows which are stored in a txt file (30mb).
I use ‘executemany’ to write multiple rows into the database when using MariaDB which took about 20 seconds for all rows (using Python).
So, I tried the same with InfluxDB using the Python client, attached are the major steps of how i do it.
#Configuring the write api
write_api = client.write_api(write_options=WriteOptions(batch_size=10_000, flush_interval=5_000))#Creating the Point
p = Point(“Test”).field(“column_1”,value_1).field(“column_2”,value_2) #having 7 fields in total#Appending the point to create a list
data.append(p)#Then writing the data as a whole into the database, I do this after collecting 200.000 points (this had the best performance), then I clean the variable “data” to start again
write_api.write(“bucket”, “org”, data)
When executing this it takes about 40 seconds which is double the time of MariaDB.
I am stuck with this problem for quite some time now because the documentation suggests that I write it in batches, which I do and in theory it should be faster than MariaDB.
But probably I am missing something
Thank you in Advance! ![]()
