Hi, I am using influxdb2 oss with version 2.3, I have a bucket with RP 3days and shard group duration 1 hour, but I am observing that shard groups are never deleting and cardinality is always increasing. The retention policy deletion check is 30 mins, and all other configurations are default only.
I can see shard groups from the day bucket was created, also disk size going up daily.
Any help will be great.
OS : linux
installed using: systemd , manual installation
Hey happy to see that I am not the only one .
My short term solution is to make a backup .
This destroy all the unnecessary chards and you reduce dramatically the size of the influx directory.
But this is not a solution and I really would like a real solution
Phil
Hi, I can also see in the logs
influxd-systemd-start.sh[24224]: ts=2022-12-14T16:55:09.952375Z lvl=error msg="Cannot create index file" log_id=0ekFFyVG000 service=storage-engine index=tsi tsi1_partition=1 op_name=tsi1_compact_log_file tsi1_log_file_id=1 error="open /grid/1/influxdata/data/9054e9141ae1c574/autogen/14/index/0/L1-00000001.tsi: permission denied"
and ls -l
ls -l /grid/1/influxdata/data/9054e9141ae1c574/autogen
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 14:40 11
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 15:40 12
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 17:40 14
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 18:40 15
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 19:40 16
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 20:40 17
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 21:40 18
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 18:40 19
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 19:40 20
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 20:40 21
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 21:40 22
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 22:26 23
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 22:29 24
drwxr-xr-x 3 influxdb influxdb 4096 Dec 14 12:40 9
not sure why this is happening. It is happening continuously. Can this be cause of some issue
Hi Phil,
Thanks for the short-term solution, have you also changed the engine-path for the DB? Also in metrics can you see retention count increasing?
Hi sorry but I can’t answer to those questions
Influxdb is in a dicker and I use the very last version .
I can give additional infos but please help me
Phil
