I have the configuration file with several tables and need to group them to represent a physical site, example, i have the 5 pcs by site (Argentina, Canada and Spain), in a central server have telegraf run, i need add tag in each site, example, 5 pc the Argentina assign static tag argentina, and 5 pc the canada assign static tag canada, etc.
I use the snmp plugin, can use the “is_tag” but i do not have the name the physical site published by snmp in all pcs for use this function.
You can assign static tags on any input plugin by using the tags option. It would require you to define a separate input for each agent you are connecting to, so that they can each have their own static tag.
