I have InfluxDB 2.3 running fine on a PC. I created a Grafana Cloud instance with the hopes of viewing the data. To do this, I need to make my InfluxDB accessible via WAN, so I created a port forwarding rule in my router and all seems to be correct. However, Grafana Cloud still cannot see it.
Do I need to do something with the config file (maybe this?) in InfluxDB to allow connections from outside the LAN? FWIW, here are my settings:
File in /etc/influxdb/config.toml
bolt-path = "/var/lib/influxdb/influxd.bolt"
engine-path = "/var/lib/influxdb/engine"
