I would like to send my telegraf metrics into 2 outputs which are: Prometheus and ElasticSearch (Kibana 5)
Is it possible? I try to configure my /etc/telegraf/telegraf.d/output.conf like that but my metrics are sent only in one
[[outputs.prometheus_client]]
listen = ":9126"
path="/metrics"
[[outputs.socket_writer]]
address = "tcp://myclusteraddress:5005"
keep_alive_period = "5m"
data_format = "json"
Thank
You should be able to configure multiple outputs within Telegraf as you describe.
Can you confirm which plugin is working?
Are you receiving data at tcp://myclusteraddress:5005?
Can you view the Prometheus metrics by visiting the /metrics endpoint in your browser?
I am receiving data in my Kibana but for the prometheus metrics I can only reach them from the localhost
Try using http://0.0.0.0:9126 as the listen address in your Prometheus output configuration:
listen = "http://0.0.0.0:9126"
path="/metrics"
This looks like an issue with your network or network configuration. Can you please share more details about your deployment environment? Are you using Docker? Kubernetes?
Yes, my bad sorry I forgot to disabled my firewalld …
