Selecting data with offset results in slow query
Good day,
I’ve got a very simple setup. I’m inserting cryptocurrency prices into my measurement:
time                price   symbol
1551709629137423000 46      LTCUSD
1551709629139537000 3736.32 BTCUSD
1551709629157560000 0.3045  XRPUSD
1551709632229084000 0.3046  XRPUSD
1551709635291219000 3736.46 BTCUSD
I’m trying to group the data into 15 minute bars with the following query:
select first(price) AS open, last(price) AS close, max(price) AS high, min(price) AS low from ticks where symbol = 'BTCUSD' group by time(15m), symbol
This works fine and I’m getting the following result:
time                open    close   high    low
1551708900000000000 3736.32 3738.37 3738.37 3736.32
1551709800000000000 3738.11 3738.66 3738.66 3737.64
1551710700000000000 3736.66 3736.66 3736.67 3736.66
However, now I want to query 15 minute bars, but with an offset of +1 minute. So I want the bars to start at minute 1, 16, 31 and 46. As far as I understand I can achieve it with ‘group by time(15m,1m)’ but when I do that my query times out and never returns any records.
Any ideas on what I’m doing wrong?
Hi Rickman ,
I have done a simple test and I have also a timeout , no results …
I guess it is a bug ?
I have found a workaround , if you add “and time > now() -3w” for example it works
I have stopped my ‘bad’ query with ctrl-c and that shows that the query starts from 5 october 1694
2 weeks before the British/American colonial forces, led by Sir William Phips, fail to seize Quebec from the French.
ERR: ll],[“1694-10-05T02:08:26.290448384Z”
Ok I figured it out myself. I needed to include an additional where statement stating from which point in time I wanted to query, because otherwise it would try to fill from the beginning of time :wink:
MarkV: Yes you’re correct. It seems like a bug which causes it to fill the result set from 1694 till now. Setting a start date is a good workaround for me.
Looks like you’ve run into this:
