Influxdb version: 1.7.6
I have a problem to request (select) values called “null”.
I have a 1st script (launched once a day) that updates 2 field (host, value_op) for LOSS measurement.
Then, I have a 2nd script launched every 5 minutes, which updates the field “value”.
So, for data, I sometimes have empty values for some tag.
I would like to recover only the non-zero values of “value”.
SELECT value,value_op FROM LOSS WHERE (host =~ /^toto/);
time value value_op
1574258100000000000 1
1574258400000000000 1
1574258700000000000 1
1574259000000000000 1
1574259300000000000 1
1574259600000000000 1
1574259900000000000 1
1574260200000000000 1
1574260500000000000 1
1574260800000000000 1
1574261100000000000 1
1574261400000000000 1
1574261700000000000 1
1574262000000000000 1
1574262300000000000 1
1574262600000000000 1
1574262900000000000 0 1
1574263200000000000 0 1
1574263500000000000 0 1
1574263800000000000 0 1
1574264100000000000 0 1
1574264400000000000 0 1
1574264700000000000 0 1
1574265000000000000 0 1
1574265300000000000 0 1
1574265600000000000 0 1
1574265900000000000 0 1
1574266200000000000 0 1
1574266500000000000 0 1
1574266800000000000 0 1
1574267100000000000 0 1
1574267400000000000 0 1
1574267700000000000 0 1
1574268000000000000 0 1
SELECT value,value_op FROM LOSS WHERE (host =~ /^toto/ and value!=‘’);
SELECT value,value_op FROM LOSS WHERE (host =~ /^toto/ and value !~ /./);
I have no results.
Is it possible to ignore the null values in a select influxdb query?
Regards,
Chris.
