Hi there,
i am using [[inputs.mqtt_consumer]] and json_v2 to parse the payload of incoming messages.
I would like to split the incoming message to two different measurements.
I tried having multiples of the json_v2 parser but it appears that only the last gets emitted.
[[[inputs.mqtt_consumer.json_v2]]
measurement_name = "data"
measurement_name = "metadata"
Incoming message example:
"id": "7A",
"data": {
"payload": {
"temp": 3.09,
"hum": 19.21,
"status": "success"
"metadata": [
"channel": 7,
"frequency": 868.5,
Desired output
data,id=7A temp=3.09,hum=19.21
metadata,id=7A channel=7, frequency=868.5
