Hi there,
I have several measurements (tables) and I’m using the following query to return the data:
SELECT * FROM memory_stats,agent_stats WHERE cuid = 'DOEX71LNRBXEVQ2UIUHYCUX' LIMIT 1
When doing this query in the Influxdb CLI I get the following:
time cuid guid heap memory reason state
2017-08-02T13:41:38.510990346Z DOEX71LNRBXEVQ2UIUHYCUX DOEX71LNR USER_LOGIN
2017-08-02T13:41:55.873818934Z DOEX71LNRBXEVQ2UIUHYCUX DOEX71LNR 85.53 51.57
When querying via the HTTP API I get the following:
"cuid": "DOEX71LNRBXEVQ2UIUHYCR7",
"guid": "DOEX71LNR",
"heap": null,
"memory": null,
"reason": "",
"state": "USER_LOGIN",
"time": "2017-08-02T13:41:27.152Z"
"heap": 60.87,
"memory": 40.75,
"reason": null,
"state": null,
"time": "2017-08-02T13:41:41.966Z"
How can I specify an Influxdb query that would return the results as a single data view? (e.g. without the null values or duplicate measurements)
I need this data as a single view to “selectively” populate a table in my application.
Any suggestions?
Regards,
Antonio.
