Reset the cumulative sum based on condition
How to reset the cumulative sum based on condition?
I am trying to calculate my stocks daily position with ticker average price. I have a measurement with my transactions. Exemple:
#constant measurement,stocks_transactions
#datatype dateTime:2006-01-02,tag,tag,tag,tag,tag,long,double,double
date,Exchange,Broker,Ticker,Stock_Sector,Operation_Type,Number_Units,Unit_Price,Operation_Value
2022-05-17,B3,AA,TICKER1,Sector_1,Buy,100,18.84,1884
2022-05-11,B3,AA,TICKER1,Sector_1,Sell,-200,16.00,-3200
2022-05-10,B3,AA,TICKER1,Sector_1,Buy,100,13.79,1379
2022-05-09,B3,AA,TICKER1,Sector_1,Buy,100,15.70,1570
I am using the following query:
from(bucket: "stocks")
  |> range(start: -1y)
  |> filter(fn: (r) => r._measurement == "stocks_transactions")
  |> filter(fn: (r) => r.Ticker == "TICKER1")
  |> filter(fn: (r) => r._field == "Number_Units" or r._field == "Operation_Value")
  |> keep(columns: ["_field", "_value", "_start", "_stop", "_time", "Ticker"])
  |> sort(columns: ["_time"])
  |> cumulativeSum()
  |> map(fn: (r) => ({r with _value: float(v: r.Operation_Value) / float(v: r.Number_Units)}))
But since, on day 2022-05-11 I sold all my Ticker 1 position, the average price is “wrong” using cumulativeSum.
0       15.7    2021-06-06T10:05:57.701Z        2022-06-06T16:05:57.701Z        2022-05-09T00:00:00.000Z        100     1570    TICKER1
0       14.745  2021-06-06T10:05:57.701Z        2022-06-06T16:05:57.701Z        2022-05-10T00:00:00.000Z        200     2949    TICKER1
0       NaN         2021-06-06T10:05:57.701Z    2022-06-06T16:05:57.701Z        2022-05-11T00:00:00.000Z        0       -251    TICKER1
0       16.33   2021-06-06T10:05:57.701Z        2022-06-06T16:05:57.701Z        2022-05-17T00:00:00.000Z        100     1633    TICKER1
If I have sold all my TICKER1 position, I would like to have the cumulativeSum to start again from zero in the next Buy. Then,
my average price would be 18.84 and the Operation_Value would be 1884
I also tried using this approach.
  |> range(start: -1y)
  |> cumulativeSum()
  |> aggregateWindow(every: 1d, fn: mean, timeSrc: "_start")
  |> fill(usePrevious: true)
  |> filter(fn: (r) => exists r._value)
0       15.7    2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-09T00:00:00.000Z        100     1570    TICKER1
0       14.745  2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-10T00:00:00.000Z        200     2949    TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-11T00:00:00.000Z        0       -251    TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-12T00:00:00.000Z        0       -251    TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-13T00:00:00.000Z        0       -251    TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-14T00:00:00.000Z        0       -251    TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-15T00:00:00.000Z        0       -251    TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-16T00:00:00.000Z        0       -251    TICKER1
0       27.33   2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-17T00:00:00.000Z        100     2733    TICKER1
But then, I would need to keep only 1 row when I have 0 holdings. The output I would like:
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-12T00:00:00.000Z        0       0       TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-13T00:00:00.000Z        0       0       TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-14T00:00:00.000Z        0       0       TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-15T00:00:00.000Z        0       0       TICKER1
0       NaN     2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-16T00:00:00.000Z        0       0       TICKER1
0       18.84   2021-06-06T08:32:06.770Z        2022-06-06T14:32:06.770Z        2022-05-17T00:00:00.000Z        100     1884    TICKER1
Any ideas?
