How to reset the cumulative sum based on condition?
I am trying to calculate my stocks daily position with ticker average price. I have a measurement with my transactions. Exemple:
#constant measurement,stocks_transactions
#datatype dateTime:2006-01-02,tag,tag,tag,tag,tag,long,double,double
date,Exchange,Broker,Ticker,Stock_Sector,Operation_Type,Number_Units,Unit_Price,Operation_Value
2022-05-17,B3,AA,TICKER1,Sector_1,Buy,100,18.84,1884
2022-05-11,B3,AA,TICKER1,Sector_1,Sell,-200,16.00,-3200
2022-05-10,B3,AA,TICKER1,Sector_1,Buy,100,13.79,1379
2022-05-09,B3,AA,TICKER1,Sector_1,Buy,100,15.70,1570
I am using the following query:
from(bucket: "stocks")
|> range(start: -1y)
|> filter(fn: (r) => r._measurement == "stocks_transactions")
|> filter(fn: (r) => r.Ticker == "TICKER1")
|> filter(fn: (r) => r._field == "Number_Units" or r._field == "Operation_Value")
|> keep(columns: ["_field", "_value", "_start", "_stop", "_time", "Ticker"])
|> sort(columns: ["_time"])
|> cumulativeSum()
|> map(fn: (r) => ({r with _value: float(v: r.Operation_Value) / float(v: r.Number_Units)}))
But since, on day 2022-05-11 I sold all my Ticker 1 position, the average price is “wrong” using cumulativeSum.
0 15.7 2021-06-06T10:05:57.701Z 2022-06-06T16:05:57.701Z 2022-05-09T00:00:00.000Z 100 1570 TICKER1
0 14.745 2021-06-06T10:05:57.701Z 2022-06-06T16:05:57.701Z 2022-05-10T00:00:00.000Z 200 2949 TICKER1
0 NaN 2021-06-06T10:05:57.701Z 2022-06-06T16:05:57.701Z 2022-05-11T00:00:00.000Z 0 -251 TICKER1
0 16.33 2021-06-06T10:05:57.701Z 2022-06-06T16:05:57.701Z 2022-05-17T00:00:00.000Z 100 1633 TICKER1
If I have sold all my TICKER1 position, I would like to have the cumulativeSum to start again from zero in the next Buy. Then,
my average price would be 18.84 and the Operation_Value would be 1884
I also tried using this approach.
|> range(start: -1y)
|> cumulativeSum()
|> aggregateWindow(every: 1d, fn: mean, timeSrc: "_start")
|> fill(usePrevious: true)
|> filter(fn: (r) => exists r._value)
0 15.7 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-09T00:00:00.000Z 100 1570 TICKER1
0 14.745 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-10T00:00:00.000Z 200 2949 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-11T00:00:00.000Z 0 -251 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-12T00:00:00.000Z 0 -251 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-13T00:00:00.000Z 0 -251 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-14T00:00:00.000Z 0 -251 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-15T00:00:00.000Z 0 -251 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-16T00:00:00.000Z 0 -251 TICKER1
0 27.33 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-17T00:00:00.000Z 100 2733 TICKER1
But then, I would need to keep only 1 row when I have 0 holdings. The output I would like:
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-12T00:00:00.000Z 0 0 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-13T00:00:00.000Z 0 0 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-14T00:00:00.000Z 0 0 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-15T00:00:00.000Z 0 0 TICKER1
0 NaN 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-16T00:00:00.000Z 0 0 TICKER1
0 18.84 2021-06-06T08:32:06.770Z 2022-06-06T14:32:06.770Z 2022-05-17T00:00:00.000Z 100 1884 TICKER1
Any ideas?
Thank you
