I was thinking of putting some fio testing data into a database to use with grafana. But doing multiple tests over time would result that data would be spread across different time ranges. I guess if I would like to have this in a combined graph, I have to resolve this with the query or so, which is messy.
Is there a way to reset the time of a series. Something like this.
reset the base of a series samples identified by host=‘ww’ and instance=‘xx’ and type=‘yy’ and type_instance=‘zz’ to 2020-01-01T00:00:00.000000000Z
or move the base of such a series with -03.2310000000Z s
